Stuck in 10.12
Ahoyskin shared this problem 8 years ago
Solved
1.1 hours, 23 tracks spanned. 1,076 tracks left. Still in the "spanned and waiting to verify" stage. Any thoughts as to why this is hung up?
Replies (2)
Thanks for getting in touch. I'm sorry you've run into an issue.
Just to check, if you resize the TuneSpan window, does the UI update?
If not, of you quit iTunes, does that kick TuneSpan back into gear?
Yes, force quitting iTunes caused it to restart. Thanks!
