order per componist possible ?
J H M Koop shared this question 13 years ago
Answered
I would like to order my iTunes files in a map per componist.
Is this possible?
Replies (3)
Thanks for getting in touch.
This is an interesting idea. At this point, it is not possible, but I will look into it.
TuneSpan does have some custom folder organization options in the Advanced Preferences. Pretty recently I added "Genre" as a custom folder option. It wouldn't be too hard to add "Composer" as a new custom folder option which you could use in the custom folder organization setting in the Advanced TuneSpan Preferences.
But, this would just apply to tracks that you choose to span through TuneSpan, this would not reorganize your normal iTunes Media.
Thanks for looking into this idea of adding "Composer" as a custom folder option.
I span all my new tracks once a month, so with one "initial span" for the tracks that are already there, this would work for me.
Regards
Joost
Great! I've already gone ahead and added "Composer" to the Custom Folder Organization in the Advanced Preferences.
It will be available in the next minor TuneSpan update, but if you would like to help test it out now, get in touch with me directly and I can send you my latest build.
http://contact.tunespan.com
